Turbo Flutter or something?
Old Mar 26, 2007 | 11:22 PM
Racevette77's Avatar
Racevette77
Default Turbo Flutter or something?
Lately 2 things have been happening to my car.
1) I used to hit 17and hold 15 psi....... now i hit 15 and hold 13 psi full throttle.
2) When im Flooring it it flutters slightly...... untill i let off the gas a tad then it feels like i get more pull w/o the flutter.
This is all new. I have done 0 mods to the car its still bone stock.
What could be causeing this and what can i do to fix it?
Thanks for help.
Oh allso i want to do a few cheep mods. Intake is allready a given.... ide like any further opinions / options ...... pls holla bout stuff that i can just bolt on w/o any tuneing that would increase performance. Tuneing later when the budget permits. For now i just want simple bolt ons ;o) Ideas pls
Again ..... Thanks for any help
Old Mar 27, 2007 | 12:16 AM
Dave_04's Avatar
Dave_04
Default RE: Turbo Flutter or something?
try your plugs and wires mine did the same thing and it was the plugs.
Old Mar 27, 2007 | 12:23 AM
Valo2170's Avatar
Valo2170
sounds like what he said and buy a wga for 145 and have a big power differnce
Old Mar 27, 2007 | 01:31 AM
silverblacksrt4's Avatar
silverblacksrt4
wastegate, plug wires, plugs.. all good things that help out alot..this has nothing to do with ur problem but once u get ur problem figured out.. motor mounts are always real nice...
Old Mar 27, 2007 | 06:57 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Stage 1 isnt real expensive, espiceally if you can find one used.
Better rims with a little wider tires (whats power w/o grip?)
Motormount inserts
Exhaust
and a must for every srt4... an OCC
Old Mar 27, 2007 | 06:59 PM
Valo2170's Avatar
Valo2170
umm i was not saying it was his problem was a wga! i said he should get that cause its cheap....
Old Mar 27, 2007 | 07:01 PM
Valo2170's Avatar
Valo2170
WERE THE FK DID YOU SEE THAT I SAID THE WG WAS HIS PROBLEM???????????? I NEVER SAID THAT !! HE ASKED WHAT ARE GOOD CHEAP MODS AND I SAID WGA!!!! I DIDNT SAY THAT GOD I HATE YOU........
