abs & brake light stays on, speedo does not register until vehicle reaches 40+ MPH
Old May 24, 2007 | 03:15 AM
upnorthpapa's Avatar
upnorthpapa
Default abs & brake light stays on, speedo does not register until vehicle reaches 40+ MPH
I drive a 1999 Ran 2500 diesel and have good brakes but the ABS & Brake lights stay on and the speedo does not register until I reach at least 40 MPH. Can you tell me where my trouble is?
Old May 24, 2007 | 03:38 AM
Midnight Runner's Avatar
Midnight Runner
Default RE: abs & brake light stays on, speedo does not register until vehicle reaches 40+ MPH
I don't know, but welcome to D.Forum.
Old May 25, 2007 | 03:39 PM
belowrdr's Avatar
belowrdr
If the cruise control is also inoperative, it's probably the vehicle distance/speed sensor. It is mounted on the tailshaft housing of the trans, where the speedo cable used to go to. Also - unplug the sensor & check for water intrusion into the electrical connector that plugs into it. That has been known to happen, causing the terminals to corrode & have poor connection to the sensor pins. Either way, if you are bothering to unplug it, I recommend a very light coating of dielectric grease be applied to the rubber seal on the connector, as prevention. Not too much grease - don't want itin the connector, may interfere with the connection - just on the connector seal. Lastly, if tranny fluid drips out when you unplug it - game over. Get a new sensor.
Hope this helps
