73 Dodge Van Charging system question
Old Sep 2, 2011 | 01:30 PM
KaryVan27's Avatar
KaryVan27
Default 73 Dodge Van Charging system question
Hi -The handle is Mike. I have a 1973 Dodge B30 KaryVan. Yes its an unusual model. Maybe the first ever Box Van? Possibly the only one running here in NW Oregon. Ugly as a bag-o-hammers but has run perfectly for the last 5 years...until now! Has a 318 V8 & automatic trans.
Motor a good runner & doesn't use a drop of oil.
Now it has charging problems. First found out the hard way that I was running on battery only. So (like a fool!) I got a new battery. OK..still running on battery, so (like a fool again) I got a new alternator. Still running on battery! Found that out the hard way when I had to be pushed out of the pump island after driving it 9 miles to get gas! Mechanic checked the alt. output with a meter. Whatdya know? 16 volts and change! Said gotta be wiring open between alt. & batt. And that I could run a straight wire from the alt. output to plus side of battery and just parallel the old circuit. But before I did that I realized that the wire from the alt. goes right to a gadget on the firewall the I have a big question about, the wire tested good with ohmmeter between each end so why run another wire?
So my question is: what is that device on the firewall that the alt. wire runs to? It has 3 terminals and is mounted on a finned thing like an electronic heat sink. 2 wires come out of the top connection and duck thru the firewall. I suspect it is toast and why my alt. is not seeing the battery but what do I know? And here is proof that I am a bigger fool than ever. I shoulda noticed that the amp gauge needle was never pointed over in the + side of the gauge ! :/
Old Sep 2, 2011 | 02:20 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I would guess it is an ECU or a ballast resistor,
FF
Old Sep 2, 2011 | 02:57 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Welcome to Dodge Forum!! Enjoy the site!!
Dusty
Old Sep 2, 2011 | 03:30 PM
KaryVan27's Avatar
KaryVan27
Thanks for the welcome! I ran the wire (heavy 10 ga. stranded) from the alternator output terminal to the + side of the battery. Voila, it is charging @ 14 to 15 volts. I just don't know if I am damaging something by running the jumper like that or not. Apparently not since if have not seen any heat, sparks or smoke and everything seems to work. So I will leave it that way and play it by ear! If anyone thinks this is the wrong thing to do. PLEASE let me know...Thanks! Nice Dodgem site!
Old Sep 2, 2011 | 08:03 PM
vpnavy's Avatar
vpnavy
Welcome aboard KaryVan27!
Old Sep 3, 2011 | 03:51 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
welcome to the site
