95 dodge neon rev limiter problem
Old Dec 10, 2012 | 06:07 AM
Neon13David's Avatar
Neon13David
Default 95 dodge neon rev limiter problem
i just put a 3 inch catback exhaust on my 95 sohc dodge neon plus a new catalytic converter and o.2 senor but now my car is only hitting 4000 rpm's and when it warms up it hits around 2000 rpm's why would it be doing this?
Old Dec 10, 2012 | 07:47 AM
cruzer55's Avatar
cruzer55
Did you change O2 with a wideband?Change it back to stock.3in exhaust robs the backpressure needed for this little motor too run correct,but sound OK.Start by changing the O2 and pull the pos from the battery to clear the PCM to re-learn the new O2,takes about 5min.Just a thought...........
