Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
nitrous question
Old Sep 27, 2007 | 09:33 PM
dodgeguy0's Avatar
dodgeguy0
Default nitrous question
have 05 ram 5.7 hemi , running nos wet kit, 75 shot , have NGK 4306 plugs gapped at .45, would like to know if a 100 shot would be ok, and what kind of pistons this thing has . thanks .dan also have 55k on motor
Old Sep 27, 2007 | 10:30 PM
rtkota5point9's Avatar
rtkota5point9
Default RE: nitrous question
What plugs are recommended for your truck? You should go at least 1 step colder than what is recomended. And I wouldn't gap them more than .35. .45 seems a little much. 100 shot should be fine. Nitrous is hard on a motor no matter what, but as long as you do it properly you shouldn't have any problems. Especially with such low miles.
Old Sep 27, 2007 | 10:41 PM
dodgeguy0's Avatar
dodgeguy0
the NGKs are one step colder plug.
Old Sep 27, 2007 | 10:48 PM
dodgeguy0's Avatar
dodgeguy0
also normally gapped at .50, I see you have alcohol injection , what kind of power do you get from that and how safe is it compared tp nitrous, thanks for info
Old Sep 28, 2007 | 05:19 PM
rtkota5point9
You don't really get any power from the alchohol injection alone. The benefit is it drastically cools the combustion chamber temps, allowing you to advance timing. On a forced induction motor this helps a lot because you normally have to retard a lot of timing to supress detonation and spark knock. Which robs a lot of power. With the alky injection you hardly have to retard any at all, gaining back a lot of that lost power. So your HP /per PSI ratio increases quite a bit.
Old Oct 10, 2007 | 06:03 AM
BLOWNSS/T's Avatar
BLOWNSS/T
One step colder than factory and gapped at 35. Just don't get greedy with the n20 and you can spray for a good while.
