Is it true I can't tow the same and still havea supercharger
prety much the subject says it all can I tow the same weight the same if I get a suppercharger it makes scence that I could tow more I have a 2nd gen 88-93 (I think 2nd gen)5.2 liter Dodge Ram and then does anyone know were to find a cheap nice one.... okay those words don't really go togeahter but that's okay!
Pan
Pan
88-93 is still 1st generation.
1994-2001 1/2 tons & 2002 3/4 ton & 1 ton Trucks comprise the 2nd generation of Rams.
And it depends on the type of supercharger. Most kits sold for the Rams are CSC kits, and will allow you to tow the same amount of weight. Towing limits aren't dependant on the motor as much as what the truck can handle.
Turbos on the other hand aren't so good when it comes to towing...unless they're attached to a Diesel motor...which is a completely different animal. [8D]
