neon NOS????
i just picked up a almost complete NOS kit from a friend the other day....it originally came of a honda civic...does anyone knoe of a way to hook this up on my 98 neon???? its a NOS 10lb bottle, fogger injectors...and im not sure what else....i dont even know what is missing from the kit...
does anyone know where there might be a pictorial how-to????
Nitrous can be installed on any motor. I've seen it installed on a lawn mower. As with anything its best to do your own research though.
your kit should include: depending on the type
1: a bottle(10lbs or 12lbs)
2: a solenoid (if its a wet kit you will need a solenoid for fuel
and one for the nitrous)
3: steel braided lines(one from the bottle to the solenoid
the other from the solenoid to the nozzle )
4: an arming swith
5: and a swith to spray
6: the proper nozzles
mount your bottle (most people put it in the trunk)
run steel line to the engine bay
tap your intake tube for the nozzle
locate a good spot for your switch
and let it rip. dont forget to fill the bottle of course. cost me $50 for a 10lbs bottle I think.
Best to keep the shot under 50 for stock engines. any higher and you will have to adjust spark timing. I didnt go over a 35 with my setup.
Not sure what kit you have but venoms kit is computerized so it has a seperate computer that sprays according to the throttle position. Please add on if i missed anything.
4: an arming swith
