2006 Gemballa Mirage Evolution
Old Aug 2, 2005 | 01:54 AM
Midnight SRT's Avatar
Midnight SRT
Nightly Creeper
Default 2006 Gemballa Mirage Evolution
Ok, this is the sexiest car I have ever seen. It's too bad it's a photshop. I hope it actually turns out this way!
Yes, those are a photoshops. However, Gemballa's latest proposal is set to become to the most outrageous supercar.
Gemballa USA is seriously representing that they are going to modify a Carrera GT in much the same way they push out the current 911 to make over 750 bhp. That is, attach twin turbochargers and make a 1000 bhp monster.
However, Gemballa's ambitions don't end there. This hypothetical makeover also includes a gullwing doors and a new carbon fiber roof, tested in the wind tunnel for 250 mph crusing.
Do we believe this? Not yet. But if these photoshop images make the press rounds, maybe a CGT owner that doesn't believe in warranties will supply a donor car. Unfortunately, Gemballa told the Dupont Registry it would take 1.5 million euros to complete the upgrade. Our fingers are still crossed.
In Detail
price $2 000 000 USD
engine Modified V10 w/Low Compression Pistons
position Mid Longitudinal
aspiration Twin Turbochargers
valvetrain DOHC 4 Valves per Cyl
fuel feed Sequential Multi-Point Fuel Injection
displacement 5733 cc / 349.8 cu in
bore 98 mm / 3.86 in
stroke 76 mm / 2.99 in
power 745.7 kw / 1000 bhp @ Not Available rpm
hp per litre 174.43 bhp per litre
bhp/weight 724.64 bhp per weight
drive wheels RWD w/ASR 5.7, LSD
body / frame Carbon Fibre Body over Carbon Fiber Reinforced Plasitc Frame
front brakes Internally Vented & Cross Drilled Ceramic Composite Discs w/6-Piston Calipers, ABS
f brake size 400 mm / 15.7 in
rear brakes Internally Vented & Cross Drilled Ceramic Composite Discs w/6-Piston Calipers, ABS
r brake size 400 mm / 15.7 in
front wheels F 48.3 x 25.4 cm / 19 x 10 in
rear wheels R 50.8 x 33.0 cm / 20 x 13 in
front tire size 275/30-19
rear tire size 345/25-20
steering Rack & Pinion w/Power Steering
f suspension Double Wishbones w/Inboard Springs & Dampers
r suspension Double Wishbones w/Inboard Springs & Dampers
weight 1380 kg / 3042 lbs
transmission 6-Speed Race-Sourced Transaxle
gear ratios Not Available36:1
0 - 60 mph Not Available seconds
Old Aug 2, 2005 | 02:07 AM
ramfan5.9's Avatar
ramfan5.9
Default RE: 2006 Gemballa Mirage Evolution
wow, teh hottness
Old Aug 2, 2005 | 02:32 AM
ViperGTS's Avatar
ViperGTS
The definition of a sexy car [sm=hail.gif]
-Matt-
Old Aug 2, 2005 | 02:37 AM
highrevr/tflea's Avatar
highrevr/tflea
looks like the carerra
Old Dec 27, 2005 | 02:35 AM
DevilsReject's Avatar
DevilsReject
Noob Assassin
Looks like my modded Carrera GT from NFS: Most Wanted...
Old Dec 27, 2005 | 04:15 PM
ViperGTS's Avatar
ViperGTS
Speaking of the Carrera GT, if this thing's based from it...production stopped because of some airbag issue not being 3rd staged or something..
-Matt-
