Mark this thread as Unsold
Dodge 545RFE ATF billet triple disc stall converter with ATF4+
Located near Ann Arbor Michigan.
Completely rebuilt by Patrick at ATF and not used since rebuild. Triple disk billet stall converter from ATF. This is for a 545RFE tranny and for 5.7 Hemi or 4.7 L engine. This will fit Dakota, Ram or Durango with the 545RFE transmission. This converter was completely rebuilt by Patrick at ATF. It stalled at 3k behind a 5700lb QC Hemi RAM with 400ft/lbs torque. According to Patrick it will stall around 27-2800 behind a stock hemi ram or Durango and 2500 behind 4.7 Durango or Dakota.
This converter sells $1200 plus the $400 core. This is for the 2003+ 545RFE transmissions. Website for info on this converter is here:
http://www.atfspeed.com
I also have 16 quarts of ATF4+ and the 2 new filters Ill throw in for the asking price. The fluid is over $100 and the filters were over $50.
$600 for everything
Call John at 248-631-8082. Items are located near Ann Arbor Michigan
If there are any questions in the converter call me and Ill give you Patricks number and you can talk to him yourself.
$600 for everything
