02 RAM 5.9L PCM Problem?
I have an 02 ram with a 5.9L and 78,000 miles. it has a superchips programmer intake and cat back exhaust.A while back all the warning lights started going off and the abs pump started running. I shut the truck off, let it sit, restarted it and it was fine. A few months later it did the same thing again. once again i Shut it off and it was fine. A few weeks after that i was pulling into my house and it just shut off. I resstarted it and it was fine except that when i reved it up it would idle down to about 400RPM and then recover. I let it sit for 4days and when i camehome i went to start it and it would fire, spit and sputter then die. i checkedfor codes with my programmer and there were none. then i check the program and it read not original program, call superchips.I can hear the fuel pump turning on and off when the ignition is on and every once in a while it will fire up and idle for a few seconds then shut off. If i hold the throttle and start it it will start and rev with a bit of a sputter and if i hold it steady it surges.I think it may be the pcm. Any ideas?
RE: 02 RAM 5.9L PCM Problem?
It turns out it was the pcm. Installed a rebuilt and the truck runs perfect.
