PCM & Fuel Systems Talk about the powertrain control module, fuel systems and delivery, customization and more.
MDS? What?
Old Feb 18, 2004 | 12:32 AM
BBHP13's Avatar
BBHP13
Default MDS? What?
I just got my new Magnum thing in the mail. It says the the RT Hemi version will have a Multipal Displacement system. I assume that this is the same as the old Caddy V-8/6/4 only controlled by the PCM. Anyone deep into the Hemi computers? Anyone reprogramming them yet? Please let me know. If this is not an option setup on the magnum, I won't be buying one........
Old Apr 18, 2004 | 08:03 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: MDS? What?
Your correct, it is the 4-6-8 system. I know that it will be in the 300C's, but I do not know if it will be in the Magnum with that system or not.
Old May 4, 2004 | 05:30 PM
crippyram77's Avatar
crippyram77
The MDS system(Multi-Displacement system) is not like the old caddy 4-6-8. It is only a 4-8 system which produces 17 mpg in the city and 25 highway. It only uses the power of all 8 cylinders when you need them and goes from 4-8 in 40 miliseconds. So you'll have power from all 8 cylinders before you even realize you've punched the throttle. MDS is a much more advanced system than a caddilac system from the early eighties. Given the option, I wouldn't disable it.
Old May 5, 2004 | 01:30 PM
71RoadRunner
Yep, it's now a 4-8 system, but it was originally being advertised as a 4-6-8 system a few years back.
