B&G Flash Or Hypertec III
I got some internall mods that Hypertec and Super Chips have sent me E-mails back saying that there system's only work with stock or close to stock motors. But I like the fact that you can program the computor to run different tire's and ratio's. Also shift point's. I would like to play with those tho.
What do I do?
What do I do?
first off with the mods you have done you will get more from a custom flash than a hypertech ,but i would not suggest b&g i had them do mine ,when i got it back he never moved the speed limiter and the rev limiter ,which i had to find out when i was racing,so i had to send it back then he only bumped up the speed to 125 i told him 140 ,to make a long story short i sent it to socaldakota.com they did me up right for the same price,,hope this helps
I had nothing but problems with my BG tune... and after giving Dave 4 attempts to nail it down I threw in the towel. The BG tune was more than .2 slower than stock in the 1/8 and .5 slower than the superchips in the 1/8 mile... It was truly a nighmare and I would not wish the BG tune on my worst enemy.
Also keep in mind... once you pay for it, and it does NOT work as you expect... he will NOT give you a refund. the only reason why i received a refund was because I purchased it through FAST MAN.... and even Dan did not want to refund my money... but he did the right thing in the end because I have been doing business with him for long time. So if you do go through with the BG tune... YOU OWN IT weather it works or not and it is NOT backed up with a refund... Thats an expensive gamble on somthing that may not work.
SPEED SAFE, AIR RAM
SPEED SAFE, AIR RAM
