PCM & Fuel Systems Talk about the powertrain control module, fuel systems and delivery, customization and more.
Code P0455
Old Dec 7, 2006 | 04:07 PM
tntitans21399's Avatar
tntitans21399
Default Code P0455
My 2003 Dodge Dakota V6 3.9L truck has had the engine light come on and it is because of the code P0455 which is a EVAP Control System Leak Detected (gross leak). Reading a Haynes repair manual it says that most of the time it is a lose hose or charcoal canister to blame. Some people I have talked to said it could be the gas cap, so I replaced and it didn't fix it. It wouldn't be the Purge Control Solenoid or Lek Detection Pump would it? Has anyone had this happen and what was their promblem they fixed? Any help is great.
Old Mar 3, 2007 | 06:50 PM
Grapevine Motors's Avatar
Grapevine Motors
Default RE: Code P0455
You need to get a smoke test done. They fill the system with "smoke" and watch for it to come out. There will be you leak. You can buy a kit to do it your self but I'm not sure of the cost.
