PCM & Fuel Systems Talk about the powertrain control module, fuel systems and delivery, customization and more.
MAF or MAS 3.5l Magnum
Old Dec 30, 2006 | 06:12 PM
Magnum 2005's Avatar
Magnum 2005
Default MAF or MAS 3.5l Magnum
On some cars the manufacture use's a MAF what is used on the Magnum 3.5l H.O. to read the in coming air
Old Dec 31, 2006 | 09:47 PM
cali411's Avatar
cali411
Default RE: MAF or MAS 3.5l Magnum
Throttle position. It uses the TPS to reference a lookup table for fuel and spark advance and then adjusts those inputs based on O2 sensor readings, MAP, etc.
Old Jan 1, 2007 | 10:44 AM
Magnum 2005
Do you know anything about the two O2 sensors in this engine,,,,,I can read and record the sensors and they seem to report very defferent readings, one is very active and the other is not as active ,,,I just wonder if this is normal.....
