Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
89 r/c lift
Old Apr 1, 2007 | 07:01 PM
bonomo's Avatar
bonomo
Default 89 r/c lift
whats the trick to getting the bolts out of the spring hangers. I cut the bolts and the only thing left is the head coming through the frame and it wont budge also so if I need new rear shackles and shackle to frame bushings where can I find them?
Old Apr 3, 2007 | 07:29 PM
Rangerider's Avatar
Rangerider
Default RE: 89 r/c lift
I always used lots of wd 40 & the biggest hammer your buddy will let you swing while he is holding the punch. a torch helps sometimes and a lot of swearing. good luck
