New guy with wiper problems in a 88 R/C
try moving one of the wiper arms by hand. if they both move easily and together then the hardware linking the motor to them has failed. It has either slipped off or broken, You will need to remove the vented cowl at the front of the windshield to fix them.
I forgot to ask this before, do you have the Intermitant operation option?
The wiper motor is a steper motor. there are 4 powerlines to it and the chassis has a ground strap attached to one of the mounting lugs. The controller is in the switch. The switch takes the battery feed and splits it out to lines A, B, P1 and P2 which goto the motor. My problem was both a bad ground and a faulty coil in the motor. it is easy to test the ground by clipping a booster cable between the wiper motor mount, and the negative battery pole.
If you still havent gotten this going, let me know.
