Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
help////
Old Apr 14, 2007 | 12:29 AM
pacifica_kid's Avatar
pacifica_kid
Default help////
have an 89 ram charger it wont start 318 f.iauto/ when i turn the key on you can here a relay come on then off i check it with the book its for the dis. i have no power to the dis... any help would be nice thanks///
Old May 22, 2007 | 02:43 PM
HellaciousHemi's Avatar
HellaciousHemi
Default RE: help////
Ok, as in WONT START, does the starter click and the engine turns but no fire? 1st Does this have Fuel injection or Carb? 2nd check the Fuse/Power wirefor getting you power to your distributor.
Old Jun 2, 2007 | 03:00 PM
89Ramcharger's Avatar
89Ramcharger
318 f.i? hmmmm try turning the key to the on position then wait for the f.p to kick on then turn the key to the off position do it again for 3 or 4 more times if no start let me know
