Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
no fire
Old Oct 17, 2007 | 12:30 AM
1990RCHARGER's Avatar
1990RCHARGER
Default no fire
I have just rebuilt the top half of the motor on a 1990 Dodge Ramcharger. Went to start and nothing. I replaced the starter and the motor turns over but it is not getting any spark. Just replaced spark plugs and wires. Any suggestions?
Old Oct 17, 2007 | 10:11 AM
1996Ram318's Avatar
1996Ram318
Default RE: no fire
Try unhooking your coil wire from the distributor and holding it near a clean ground while someone cranks the motor. If it sparks, then you know to start at the distributor. If no spark, I`d replace the coil.
Old Oct 27, 2007 | 06:51 AM
sore_thumb_garage's Avatar
sore_thumb_garage
Default RE: no fire
make sure you check both balisters befor you go replacing the coil i was having that problem with my 86 rc and that is what it was we also had that prob. with our wood chipper that has a slant 6 in it so check those first
Old Nov 6, 2007 | 02:48 AM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Default RE: no fire
Bad coil is not a common problem-check resistance across the terminals. Prestolite or Essex should be 9-12K ohms,15k-19k for Diamond. Primary resistance is 1.35-1.55 ohms for all. And check for key-on power to the positive coil terminal. If it ohms out OK and has power, then it's a signal problem and we need to know which engine/what fuel system you have to further assist.
