Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
Need Info - 1983 Dodge Ramcharger 4x4 Electrical
Old Nov 20, 2007 | 01:33 PM
OKTrap's Avatar
OKTrap
Default Need Info - 1983 Dodge Ramcharger 4x4 Electrical
I have a 1983 Dodge Ramcharger 4x4 with an apparent electrical problem. I have a new alternator, battery & voltage regulator installed ... however, I get no chargeback to the battery from the alternator. The alternator tested good at O'Reilly Auto yesterday ... 11/19/07.
I am an electronics technician that cannot figure out why this vehicle will not charge back to the battery. Any help would be greatly appreciated.
By the way ... all wiring harneses check good under the hood.
Thank you:
Old Nov 20, 2007 | 07:51 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Default RE: Need Info - 1983 Dodge Ramcharger 4x4 Electrical
Is it the correct alternator? Some only need one field wire, others require two.
If all else fails, GM one-wire.
Old Nov 20, 2007 | 10:24 PM
OKTrap's Avatar
OKTrap
It is the alternator required according to both the manual ... and to the parts house.
Old Nov 21, 2007 | 06:37 PM
OKTrap's Avatar
OKTrap
After extensive testing, incuding a full field test ... I found the problem. I had to replace the voltage regulator 3 times, before getting a good one. Two were bad out of the box. I could understand if they were made overseas ... but these were made in America ... shame.
Old Dec 20, 2007 | 10:23 PM
ramitupurs84's Avatar
ramitupurs84
I bought a dipstick tube from the PAW catalog that said it was made in America but it broke when I put it in and it was clearly stamped Made in China...they said they can't control that...
