Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
318 Rebuild or Replace Engine
Old Jan 3, 2009 | 11:17 AM
83 Ram Charger's Avatar
83 Ram Charger
Question 318 Rebuild or Replace Engine
1983 Dodge Ram Charger 318. Engine lost power while driving. Pull over within 1 minute. Blew By-pass hose. Engine hot did not come on and there was collant in the radiator and at the pump. Replace hose. Engine will not start. I have white spartk at all spark plugs. Compresion test 117-125 all cylinders except #2 it is 80. Added oil and it stayed at 80. Is it a valve? Had a valve job @ 90K miles. engine has 327K miles. Can it be revalved or should I rebuild complete engine or buy a rebuilt from Standard Auto Engines 5 yr warranty unlimited miles? Do you know of an engine shop in Winston Salem, NC
Old Jan 5, 2009 | 06:46 PM
moparborn's Avatar
moparborn
With that many miles,if it is in your budget go with a rebuilt,your original motor may need more that expected to be relyable.
