Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
blinker problem
Old Sep 26, 2009 | 05:07 PM
nrhramman's Avatar
nrhramman
Default blinker problem
just had a shelby 318 put into my 85 ramcharger now when i turn on the headlights the blinkers just stay on they dont blink what am i missing here
Old Sep 27, 2009 | 12:24 AM
jeffs_62's Avatar
jeffs_62
Do they blink normally when the headlights are off?
Check all your gound straps.
You should have one from the negative battery terminal to the body, one from the battery to the motor, and one from the motor to the fire wall.
Also, do your hazzard flashers work?
If they don't, you might investigate further.
Old Sep 27, 2009 | 07:26 AM
nrhramman's Avatar
nrhramman
yes they do and hazards work right one blinks when lights are on only left one dont
Old Sep 27, 2009 | 05:06 PM
jeffs_62's Avatar
jeffs_62
Did you check all your signal bulbs? Fuses? Fuse block to harness connection?
Are there any wires pinched from the replacement of the engine?
Old Sep 28, 2009 | 05:49 PM
nrhramman's Avatar
nrhramman
dont look like they are replaced all bulbs and the fuses
Old Sep 29, 2009 | 11:47 PM
jeffs_62's Avatar
jeffs_62
are all your ground wires good and tight.
I had a car once that I learned that lesson on.
When I turned on the left turn signal the dash lights would blink, right one, the buzzer would go off. When I honked the horn, everything would turn on.
Unfortunately I don't know what else to tell you.
Good luck and keep us posted.
