Tranny locked up i think
My truck my grandfather gave me is a 1979 dodge power wagon and it is locked up and wont shift or anything is it a 4 speed. The engine runs but something is locked to were it wont do anything. please help me
Well if you are mechanically inclined start taking it apart, other than that your gonna need to goto a tranny shop. Its a 79 so problems are not going to be out of the ordinary. I do not recomend doing the internal tranny work yourself unless you know what you are doing. Most likely you will need to replace or rebuild the tranny.
Transmission is locked up. Need to pull the top of tranny off and see if the shifting forks are where they're suppose to be. Also need to make sure gears are where they're suppose to be when you put the top of tranny back on. Can be done through the floorboard of the truck. Do not need to drop tranny to check this.
You need to try and shift both transfer and tranny. If you have drive lines hooked up and transfer case in neutral it should role. If it doesn't, then your problem is a locked transmission.
