Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
limited slips in a 1993 Ramcharger
Old Dec 12, 2005 | 04:04 PM
jswanny21's Avatar
jswanny21
Default limited slips in a 1993 Ramcharger
I have a '93 ramcharger and the rear end grindings when turning, but only after you drive it for a half hour or more. I have been told that it simply needs a fluid change, but i was also told the limited slip is going bad or a bearing is going bad. can anyone shed any light on this subject? thankyou
Old Dec 14, 2005 | 04:15 AM
Chump's Avatar
Chump
Default RE: limited slips in a 1993 Ramcharger
ORIGINAL: jswanny21
If you have the Anti-Spin rear end it's a 9.25". Go down to NAPA and pick up a cover gasket and about 3 qts of 80W-90 weight oil. Go down to Chrysler and pick up a bottle of Anti-Spin Friction Modifier, this is the factory additive that is designed to keep the Anti-Spin/Limited Slip plates from chattering on turns. Change all and drive for a couple of days and see what happens. This would be your cheapest first step.
Old Nov 11, 2011 | 11:14 PM
moe7404's Avatar
moe7404
if its a 7 1/4 your are hosed. do NOT put a 7 1/4 back in. when you go to put a bigger one in, you will need different length drive shaft, and other things. each rear end length needs a diff length drive shaft, and other things
