Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
1985 dodge ram charger question
Old Apr 18, 2020 | 11:31 PM
J.W. COWAN's Avatar
J.W. COWAN
Red face 1985 dodge ram charger question
i want to replace the turn signal lens on my 85 ramcharger, is this a simple process
i am also replacing the tail light lens, have done this before, no problem....
a response would be greatly appreciated on the turn signal lens replacement
Old Apr 19, 2020 | 11:30 AM
Down Eastah's Avatar
Down Eastah
If I remember correctly the ones in the grill are molded to the head light bezels but available on-line. That restoration parts warehouse place for American Trucks has them
If it's an 85 grill LOL
Old Apr 19, 2020 | 11:54 AM
ol' grouch's Avatar
ol' grouch
Just remove the screws holding the headlight bezel in and then unplug the connector the the turn signal bulbs. The only difficult part will be if the screws have rust and don't want to come out without wallowing the screw head out. If they are difficult, get some valve lapping compound and dip the tip of the screw driver in it. This will let it "bite" and twist the screw out, not round the head out.
Old Apr 20, 2020 | 02:02 AM
Down Eastah
Yea old steel screws suck. You can try to screw them out, but don"t strip the heads out to bad if they won't turn.That way if you have to drill the head off the old rusty screw will have a good spot for the drill. Drill bit should be about the same size a screw shaft so it will take the head right off without any damage to any thing else. Also spray the screws as good as possible with some penetrating oil. you can use some vice grips to try and get the rest of the screw out. Home depot for screws and the auto parts store for new screw clips. Once the grill shell is off, repeat until you have off what you want. Sounds a little tough but not so bad. Just drill enough to take the screw head off and if you have to remember if you have to do that on a plastic part have water close to keep plastic cool or the friction will melt or deform your part.
