Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
Need Help Finding " Fuel Pump Assembly"
Old Sep 17, 2023 | 12:28 PM
Sore Toe's Avatar
Sore Toe
Default Need Help Finding " Fuel Pump Assembly"
I hope this note finds all well. My daughter & I are working on a 1990 Dodge Ramcharger, 5.2 L. We dropped the fuel tank and removed the attached. We need to purchase a new assembly but conventIonal outlets/ routes such as NAPA cannot provide. Where can I find a new or newer " fuel Pump assembly".?? We purchased the pump but spring, containment vessel, fuel sending unit, etc....this is what i am looking for...Appreciate the help.
Old Sep 17, 2023 | 12:51 PM
ol' grouch's Avatar
ol' grouch
Does this look like what you need?
Does this look like what you have? You don't have to get it on Fleabay but it has a part number. Since the Ramcharger was going away, I can't see them changing much.
https://www.ebay.com/itm/30496382110...3ABFBMjp3PwNRi
Old Sep 17, 2023 | 04:07 PM
Sore Toe's Avatar
Sore Toe
Default Fuel pump assy
Yes..however do u think I have to reuse the spring???
Old Sep 18, 2023 | 02:13 AM
ol' grouch's Avatar
ol' grouch
I'm not sure what spring you're talking about. Do you mean the lock ring on the top of the assembly to hold it in the tank? If it's straight and not rusty, if you can clean it up, yeah, you can reuse it. I generally get a new one and save the old one for emergencies when one I'm working with breaks.
Looking at the pump you pulled, I hope you cleaned the tank good. I mean REALLY good as any dirt and rust in there will go into your new pump.
Old Sep 18, 2023 | 07:00 PM
Moparite's Avatar
Moparite
You may want to ask the guy on ebay where he got that #? It doesn't match the one for pick up or ramcharger either motor according to rockauto. This is the Dorman # they give 2630336. I looked up on the Dorman site and i got the same #. Also looked it up on parts geek and no such #. I think their "guaranteed fit" is full of Why are you looking on ebay for parts anyway? If you must get # then look there. That thing is toast! Don't use anything from it! What does the inside of the tank look like?
https://www.rockauto.com/en/moreinfo...WCJD0yiA%3D%3D
Old Sep 19, 2023 | 09:45 AM
ol' grouch's Avatar
ol' grouch
Ebay is easy to look up on and has pictures. I don't always buy there, but the photos give a good reference.
Old Sep 19, 2023 | 05:49 PM
Sore Toe's Avatar
Sore Toe
thank you very much- very helpful!
Old Sep 19, 2023 | 07:19 PM
Moparite's Avatar
Moparite
And not always what you are buying "stock photo", As in this case a # that doesn't match anything. So what is the pic of? All the other links i posted including parts geek have pics also.
Old Sep 12, 2025 | 03:30 PM
kdbreault's Avatar
kdbreault
Default Parts
Rockauto
