Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
DANA 44 DISCONNECT CAN I REPLCAE SHAFT WITH OLDER FULL SHAFT
Old Jan 25, 2007 | 03:24 PM
RAMCHARGER88's Avatar
RAMCHARGER88
Default DANA 44 DISCONNECT CAN I REPLCAE SHAFT WITH OLDER FULL SHAFT
I HAVE A 88 RAMCHARGER THAT I BOUGHT NOT TO LONG AGO JUST HAD IT LIFT AND GEARS INSTALLED AND FIRST TIME OUT SHATERED THE FRONT INNER SHAFT AT THE U JOINTS I HAVE FOUND EVERYTHING I NEEDED TO PUT IT BACK TOGETHER EXCEPT THE "3RD MEMBER" INNER SHAFT ON THE DISCONNECT SIDE THAT GOES TO THE OUT SHAFT BUT I HAVE FROM MY OLD 76 A FULL LENGHT 44 SHAFT SO MY QUESTION IS CAN I PULL OUT THE DISCONNECT SHAFTS AND REPLACE IT WITH A FULL SHAFT THANKS IN ADAVANE FOR ANY HELP
Old Feb 10, 2007 | 08:04 AM
Chump's Avatar
Chump
Default RE: DANA 44 DISCONNECT CAN I REPLCAE SHAFT WITH OLDER FULL SHAFT
76 shafts wont work. Which shaft are you looking for? Also try posting at www.ramchargercentral.com in there parts wanted classifieds. www.junkyarddog.com also
