Ram Chargers Axles and Axle Ratios?
Could somebody tell what axles are in a 8 ram charger. It looks like a chrysler 9.25 and dana 44 but I just want to make sure. And also the axle ratios.
Its either the 9.25 or Dana 60 and Dana 44 front is correct.
axle ratios are all different...usually you can jack up the back end of the truck, mark the driveshaft with chalk and then spin a back tire and count the revolutions to figure that out within reason.
If you have the 5.9L 360, you most likely have the D44 front and Chrys. 9.25" rear. These generally came with stock 3.23 gears. Very rarely did they have anything lower from the factory.
