Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
89 wiring schematic
Old Mar 18, 2007 | 10:03 PM
lilfroger's Avatar
lilfroger
Default 89 wiring schematic
Hubby just bought an 89 RamCharger - dash lights flicker / don't turn on / don't turn off - - Oh yeah this thing is going to be a nightmare.
I ran down and grabed him a Chiltons but it isn't specific enought. What I need is any wireing info on the dash - ohms - volts - step downs the whole nine yards.
Thanks!
Old Mar 20, 2007 | 08:29 PM
Rangerider's Avatar
Rangerider
Default RE: 89 wiring schematic
This might sound funny but look under the dash in the dark and look for sparks.Also check anywhere that there is a wire runnuing through the firewall that is unprotected. good luck.
Old Mar 31, 2007 | 04:34 AM
Chump's Avatar
Chump
If the dash illumination lights are flickering then you may have a ground problem or a bad dimmer/headlight switch or connector.
Old Mar 31, 2007 | 05:43 AM
i11m10c2's Avatar
i11m10c2
think i got it fixed loose ground but the light swich wiring looks streched out of connector so will se how it goes its in for new heads so i can run headders without smog ports
