[5th Gen : 08+]: Grinding noise when pressing on accelerator
Old Mar 12, 2016 | 08:55 AM
T6954's Avatar
T6954
Default Grinding noise when pressing on accelerator
Hi,
I just bought a preowned 2010 Dodge Grand Caravan SXT and had a repurchase inspection done and all was fine the only thing that showed up was a minor leak in the transmission pan.
Now we are hearing a grinding type noise only when we press on the accelerator. When we let off the gas pedal it disappears. It also seems and feels like the noise is worse on the passenger front side of the vehicle. It seems to be the worst at city speeds and tends to go away at highway speeds. Doesn't seem to have anything to do with brakes as there is no noise when you brake.
Old Mar 12, 2016 | 08:59 AM
Originally Posted by T6954
Hi,
Possibly a bad CV joint or wheel bearing. Pull the wheel off and inspect. Welcome to the forum.
Old Mar 12, 2016 | 09:02 AM
T6954's Avatar
T6954
Thanks I will look into that. However we had CV joint issues with other vehicles before and doesn't seem to be the same kind of noise.
Old Mar 12, 2016 | 10:22 AM
T6954's Avatar
T6954
Default jkeaton - Not CV joint of wheel bearing
Hi it is not the CV joint or wheel bearing is it anything else you can think of?
Old Mar 12, 2016 | 11:07 AM
Does it do it while sitting still or only when driving?
Old Mar 14, 2016 | 02:55 PM
DodgeCares's Avatar
DodgeCares
I'm not sure how long ago you purchased this vehicle, or where you purchased it from, but have you contacted the seller and/or dealership?
Old Feb 29, 2020 | 06:13 PM
R. Lovins's Avatar
R. Lovins
Default I have the Same problem
I have an 08 Dodge grand Caravan I just purchased did you figure out what it was that was making the noise mine does the same thing when I come to a stop and then I go to take off grinding noise sounds like it’s coming under Neath the pedal goes away after I takeoff seems pretty quick
Old Apr 18, 2021 | 08:22 PM
Robert M. Stewart's Avatar
Robert M. Stewart
Default I have 2009 3.3SE that just started doing this grinding noise too!
Did you ever find what it was? I have the same issue with my 3.3SE. I replaced the cv axle but did not change anything.
I searched the Internet but have yet to find anyone with a solution?
My next thoughts were the hub assembly’s.
Old Oct 17, 2023 | 06:12 PM
Robert M. Stewart
Default 2009 DGC 3.3SE grinding sound from acc pedal
so I have the same issue: hubs replaced, axels replaced, rotor and new pads, replaced.
Took it to a transmission shop, they had no idea. It shifts smoothly but only makes the noise w vibration directly behind the accelerator pedal.
no leaks of fluid, transmission fluid was replaced, filter replaced, oil & filter changed, I even tried various transmission lubricants but nothing has helped.
it only happens on hills and when I accelerate moderately, if I accelerate slowly it’s fine.
If anyone has uncovered anything let me know.
My transmission shop just said drive it until it stops working, but as far as I can see, transmission is fine it just makes this horrible noise when I accelerate.
Thanks in advance!
Robert
LA, CA
Old Yesterday | 05:42 PM
jbbunch's Avatar
jbbunch
Thanks in advance!
Robert
LA, CA
u figure it out? my 08 4.0 6 speex does it. I think its in trans or flywheel(newer). old man thinks its axle shaft(3 years old).
my guess is the compounders doing its thing cutting thru Teflon sealing ring. n when accelerate it throws drum past the fluid pressure hole slightly and u get chatter in that clutch. even tho it does feel like grinding
