99 5.9 4x4 slt having issue with idling and a sort of knock
Old 09-19-2017, 08:28 PM
Brandan K. Sites's Avatar
Brandan K. Sites
Brandan K. Sites is offline
Exclamation 99 5.9 4x4 slt having issue with idling and a sort of knock
Hello, need advice on what to do, been doing it a while, sometimes when driving at low speeds aka 10-45 ill start to lose lose power like its not getting gas or air and itll start making a knocking sound but if i push the peddle all the way to the floor itll stop for a bit, then sometimes when stoping itll idle real low almost to zero or just shut off completely, anyone else have this issue, and if so know anyway to fix it?
Old 09-20-2017, 05:33 PM
that_guy's Avatar
that_guy
that_guy is offline
Trouble idling is normally either a battery/battery connection issue or an IAC (idle air control) valve issue.
Old 09-21-2017, 06:02 PM
ecmexchange's Avatar
ecmexchange
ecmexchange is offline
Former Vendor
Default Idle issue
I'd check air filter and the fuel filter also. I know it's a silly thing to suggest but from my experience that is the culprit more times than you'd think.
