How do I run down this short?
I installed a used OE Chrysler CD/Cassette/Radio from an online dealer of such items. It worked without problems for just about a year (I did this just after I did the glass channels last Sep.) then it started cutting out. It seems like a short as it comes and goes. It generally comes back up if I sharply hit the top of the dash. I took it out, cleaned it and the connections put electrical lubricant on the connectors and reinstalled it. That seemed to fix it for a few days. Now it is doing the same thing again. At the about same time I also put in 4 new speakers.
I want to eliminate the possibility the wires or speakers are somehow the problem before I ask the seller to fix the radio.
Can some one who knows explain the steps for testing the wires for shorts? or just tell me how to narrow this down to the radio? The wires are the stock wiring down to the factory made adapters the speaker sellers gave me.
Your reply reminded me that I left out critical data. The power does not go off. The dial stays lit and indicates it is changing stations but the sound is gone. It does not give any static or scratching noise, once in a while a couple of pops comes out of the right speaker when it goes off or comes on. The sound just dies suddenly with no reason I can detect. It will happen on flat smooth road and not happen going over bumps. It is intermittent with no pattern in how often it cuts out.
I'll bet that the well known solder joint failure in older Chrysler logo'ed radios is hitting it.
See, for instance, Jeremy Schrag's article on the combo units and repairs at https://www.allpar.com/stereo/combo-deck/ (warning: I'm a paid member, I get no pop up ads; you probably will.)
RwP
RwP
