Service Tire Pressure System and Remote Keyfob Distance
Old 01-17-2018, 05:31 PM
ebland0724's Avatar
ebland0724
ebland0724 is offline
Default Service Tire Pressure System and Remote Keyfob Distance
intermittantly the "service tire pressure" is displayed and it varies between 1 and all 4 tires being "-". Also, the key fob does not work from distances, and this too varies... some days it'll unlock and remote start from 100yds away, some days i have to be withing 2ft of the truck... Question: Is the WCM the culprit?
Old 01-17-2018, 09:10 PM
SHO Rod's Avatar
SHO Rod
SHO Rod is offline
Please provide detail of the model and year of your Ram. Also, do the issues seem related to ambient temperature? Have you checked the tire pressures to make sure they are properly inflated according to the tire placard in the driver's door jamb?
-Rod
Old 01-18-2018, 10:39 PM
ebland0724's Avatar
ebland0724
-Rod
2014, 1500, Lonestar, CrewCab, 4x4. Not temp related started happening end of last summer and has continued thru the winter. Yes all four tires are inflated 39#. It’s strange because some days only one or two show the pressure, some days all four go out. Sometimes they all go out while I’m driving.
Quick Reply: Service Tire Pressure System and Remote Keyfob Distance
