07 ram 1500 club cab cooling problem
Old 03-21-2018, 07:28 PM
skull246's Avatar
skull246
skull246 is offline
Default 07 ram 1500 club cab cooling problem
k i will start from beginning ,truck had a howling sound so took it to shop water pump was shot so had it replaced took it home and parked it for 2 days, went out started it everything seem fined then once i started to drive it i could hear water running sound like i was pouring a bottle of water in to the glove box or in that area, so i took it back 3 times for this last time they found an air pocket they said , now my problem is i am getting a smell of antifreeze but not consent comes and goes and on the passenger side every once and awhile i will here like a air line making shhhhh sound and it will stop and then about 2 mins or so it will do it again , now i have no wet spots on the floor any where so i need help figuring it out going to try fixing my self if i can get help where to start and motor is 5.7
Old 03-22-2018, 12:24 AM
Scff's Avatar
Scff
Scff is offline
Sounds like you may have a leaking heater core. A pressure test on the cooling system can determine if there is a leak in the system
Old 03-22-2018, 07:12 AM
mopar4u's Avatar
mopar4u
mopar4u is offline
Might still have air in the system. Im fairly new to the ram 5.7 myself so i cant give advice on how to properly purge the cooling system of air.
as for the smell, maybe your smelling coolant cooking on the engine from when the pump was replaced? Worst case as noted above your heater core has a small leak.
Old 03-22-2018, 08:29 AM
skull246's Avatar
skull246
skull246 is offline
ya i am leaning towards heater core but i have put about 75 miles on it and fluid levels are staying the same and no wet spot on carpet and is it true i have to remove dash to replace heater core?
Old 03-22-2018, 04:44 PM
Scff's Avatar
Scff
Scff is offline
make sure you’re checking the radiator and the overflow tank. The dash has to be removed to change the heater core. If you replace it, you may as well replace the blend doors and evaporator too.
Old 03-23-2018, 10:00 AM
skull246's Avatar
skull246
skull246 is offline
well its in the shop they pressured it up last night and in morning its still the same no leaks so now there thinking maybe a plugged rad maybe so they are going to drain the system ,
Quick Reply: 07 ram 1500 club cab cooling problem
