[5th Gen : 08+]: clicking actuator, driver side, underdash
Old 06-10-2018, 06:50 AM
fj5gtx's Avatar
fj5gtx
fj5gtx is offline
Default clicking actuator, driver side, underdash
2011 GC Mainstreet. Clicking is going on with the van not running, just opening the door. Coming from the driver footwell area. I pulled the plastic away, and way up near the firewall there is an actuator that I can feel it thumping when this clicking is going on. Problem is, I'm having a heck of a time trying to access it with tools. Is there a trick? Actuator is secured with two T20 screws.
Also what is this actuator called? I'm thinking I need a new one.
Thanks!
Old 06-25-2018, 11:44 PM
fj5gtx's Avatar
fj5gtx
fj5gtx is offline
Got the old one out. One of the posts for a gear was broken, so the gear wasn't close enough and was slipping - that was the clicking noise. Put in a new one from Amazon, problem solved.
Old 11-27-2018, 07:30 AM
COLDIRON's Avatar
COLDIRON
COLDIRON is offline
Thanks, just ordered one the other day on ebay. Mine has been clicking for a few months. Watched how to replace it on you tube. It should be here by Friday. Looks like a real ball breaker to get way up there.
Old 12-11-2018, 08:55 AM
HighSierra's Avatar
HighSierra
HighSierra is offline
What is the actuator for?
Old 12-12-2018, 06:58 AM
COLDIRON's Avatar
COLDIRON
COLDIRON is offline
Hi, it is a little plastic gear box with a wire connection on it that operates the when the heat and air comes out. On the floor, out the middle dash board, defrost up at the front windshield. It's real hard to replace you have to be a snake with hands. it just has two T-20 star/torx screws. Usually one of the cheap plastic gears strip. Watch you tube. Don't forget to take the negative battery wire off don't want the air bag to blow.
Quick Reply: [5th Gen : 08+]: clicking actuator, driver side, underdash
