2002 dodge Dakota
Old 11-15-2018, 09:43 PM
Kristi paulley's Avatar
Kristi paulley
Kristi paulley is offline
Default 2002 dodge Dakota
Can you by pass the a/c unit when replacing the Serpentine belt?
Old 11-15-2018, 11:24 PM
magnethead's Avatar
magnethead
magnethead is offline
Is the clutch seized on yours? Fairly common problem.
You'll have to use a non-spec belt, but yes you can use an alternate routing going from the power steering pulley to the center idler between alternator and AC, on the 3.9/5.2/5.9. Not sure on the *.7 engines.
Quick Reply: 2002 dodge Dakota
