[4th Gen : 01-07]: Variable restrictor 4677378AB cracked an leaking
I replaced this PLASTIC variable restrictor 4677378AB for the heater system I believe, in 2021 now it appears to be leaking again. Not sure why this is happening? I heard somewhere that some people have replaced it with a piece of tubing? If so could you please reply with how it has worked out. Any problems? Last what size OD tubing metal or plastic, part number. Any links?
Thank you in advance.
Restrictor after hose with bend. Plastic 1.5 inches long. 4677378AB.
