i just got done putting a new trans in my 2001 1500 5.9 auto, when its in 2wd the 4wd light is on and when you shift to 4wd it turns off and does not shift in to 4wd, any help is appreciated.
Are the vacuum lines connected properly at the switch on top of the transfer case? You can read all about 4WD issues and how to fix them by downloading the service manual for your year truck here - https://dodgeforum.com/forum/2nd-gen...e-manuals.html
I looked and all I can find is were it says to connect the vacuum harness. all the vacuum lines on mine got either cracked or cut so I repaired them, but I think some might be miss matched, could you help with that?
my 95 the steel part of the vacuum line was rotted when i got the truck so i swapped out the front axle vacuum system to a posilock kit from rockridge 4wd only issue i had was after the first winter i had to adjust the cable a tiny bit
