How to check valve body and solenoids for being overhauled
Old 06-14-2024, 01:22 PM
GrossmeisterB's Avatar
GrossmeisterB
GrossmeisterB is offline
Default How to check valve body and solenoids for being overhauled
Cheers everyone,
I still have some trouble with my 545RFE automatic gearbox in my 2004 RAM 1500 HEMI 4x4. I want to replace the valve body with the shifter solenoids. I bought a "refurbished" valve body with solenoids online (https://djtransparts.com/).
Now I received the part and I'm not sure if and how I can check if this really has been overhauled and is not just a used unit that has just be cleaned.
Anyone got an idea how to check it?
Thanks a lot for any help!
Old 06-14-2024, 04:12 PM
Prismatic's Avatar
Prismatic
Prismatic is offline
Unless you're buying a premium unit from a speed shop with say, a billet channel plate, or from someone like ATS who will grind true an original channel plate, really that's all you'll get is a good cleaning and inspection. They might upgrade the unit with a Transgo shift kit while they're in there.
What are the issues you're continuing to have with the trans?
Old 06-14-2024, 04:40 PM
GrossmeisterB
So you might not see any "difference" from outside? Any screws that I could check maybe for being used in the process?
The issues are that in 2nd gear, when e.g. in a traffic jam, rolling at like 20mph or something, then going back on the throttle, it goes into gear very rough with a slight "bang".
Doesn't do it in 1st or 3rd. Tried changing gearbox oil first, but didn't help...
Quick Reply: How to check valve body and solenoids for being overhauled
