Shhhh, it's pulling 30,000 jigawatts. Should be good for awhile.
As long as your flyback valve can handle the strain, you should be okay but the framilator still might fail. Especially if you used an STP rather than a Fram filter.
Be sure before starting a long trip to check the alignment of the wiggly pin on the wobbly shaft. If not you may have trouble finding new thingamajig to get it re-aligned!!
Can I check the alignment myself or does it have to be done at a shop.
