[5th Gen : 08+]: Dodge caravan
Old Today, 05:10 PM
oleh's Avatar
oleh
oleh is offline
Default Dodge caravan
Good day, help me with advice. Dodge Caravan 2011 3.6. There are 3 errors P06dd, P0349, P0394. ESP turns on after I drive a little, then I turn off the engine, start it back up and drive normally again. I replaced the oil pump, changed the sensor, changed the camshaft sensor, looked at the ABS sensors on each wheel. I replaced the flywheel where the oil filter is inserted. Nothing helped. Help
Quick Reply: [5th Gen : 08+]: Dodge caravan
