3rd Gen Durango 2011+ models
Headlight Alignment
Old 10-02-2024 | 07:17 PM
NJ_Mike's Avatar
NJ_Mike
Default Headlight Alignment
2004 DD SLT. Recently replaced Driver side Front Headlight assembly. The low beam aim is low. Which way do I turn the alignment adjustment screw. Remember there are two screws to hold the bottom of the headlight. You can get access to them by inserting 10mm socket through the predesign hole on the bottom.There is a top screw secured through the wheel well. The alignment screw is tucked next to the right screw mentioned above. To make the beam shoot higher, do I turn the alignment screw right or left. I guess to could play with it, but I like to speed up the progress.
Access to the hold down screws
Note the alignment adjustment scree is tucked next to the hold down screw
Quick Reply: Headlight Alignment
