Transmission won’t shift into 3rd under acceleration
Old Apr 6, 2026 | 01:09 PM
Jimmydean91's Avatar
Jimmydean91
Default Transmission won’t shift into 3rd under acceleration
I recently put in a reman-transmission in the truck and I’m have an issue with the truck shifting into 3rd when accelerating but if you let off around 40mph, it shifts into 3rd and you reapply throttle and go. I have a check engine 22 for the engine coolant temperature sensor and I’m pretty sure it’s the plug needs replacing. However I don’t think that would cause a problem on 3rd gear alone. Any advice goes along ways. Thanks in advance.
Old Apr 6, 2026 | 02:34 PM
What are you driving?
Old Apr 6, 2026 | 02:36 PM
Jimmydean91
1995 ram 1500 5.2l rwd, I apologize I forgot to add that.
Old Apr 6, 2026 | 03:30 PM
Makes life a bit easier.
First three gears are controlled purely by hydraulics. Modified a bit by the TV cable. If the cable is sticking, or out of adjustment, or, the spring fell off, that will do odd things to shift points.
Old Apr 12, 2026 | 12:05 PM
Jimmydean91
Thank you, it seems my tv cable was way out of adjustment by around 10-14 clicks. However transmission is shifting great now. Can’t thank you enough. The only issue I have now is that code 22 engine coolant temperature sensor, I have changed the sensors and changed the plugs going to them and it’s like nothing changed. It’s been a pain in the you know what.
Old Apr 12, 2026 | 04:13 PM
Keep in mind, your truck has TWO temp sensors, I one-wire for the gauge, and a two-wire for the PCM. You want to address the two-wire feller.
Old Apr 13, 2026 | 04:47 PM
Jimmydean91
I switched out both of the sensors (the single prong and the dual prong) checked the voltage and with key on/engine off got 4.98v, I traced the wires back to the computer and found no issues with the wires. This just has me completely lost on what else to do.
Old Apr 14, 2026 | 07:31 AM
What temp is the PCM seeing? Is it just off more than it should be?
Old Yesterday | 10:36 AM
Jimmydean91
This is the reading on the gauges when warmed up
Old Yesterday | 01:35 PM
Two sensors.... That's what the one wire sensor is seeing. Need to plug in with a scanner to see what the pcm thinks engine temp is.
