Where to buy/source new hedman hedder collectors 5.2/5.9 Magnum..
.. for a set of these 5.9 magnum Hedman Hedders , 1 is sitting in 5% vinegar that started at about 3 hours to the next pic . Paid 50.00 US for them from my neighbor . Hedman part # 79540 with a stamp of 409 below the part # .. Thanks
Just the collectors??? Go to any muffler shop and they can make some up for you. Probably less than 20 bucks.
Actually I need the 2 for the manifold side , the ball/socket ( as I call this connection ) both have dents for some reason and will be hard to beat back into a 100% sealing condition . If you look at the 1 image above you can see a spot there but more are around the flang on both .
I can cut and weld , have plasma cutter , sawall , grinders and a nice lincoln HD135 welder
Yep, have the local midas muffler bend something up for ya. They should be able to do it without a problem. (assuming they have the pipe bending machine.....)
