Tech Info Archives Find Techinical Information Archived Within.
Wiring Diagrams
Old Aug 6, 2005 | 10:11 PM
alynch75's Avatar
alynch75
Default RE: Request Wiring Diagrams Here
Also I have a 2000 Dodge Avenger Sport. I am trying to figure out what sound system is in it. I am the 2nd owner. It appears to have a spearker in each door. 2 speakers in the back window area and 2 speakers up on the dash
alynch75's Avatar
alynch75
Old Aug 9, 2005 | 05:44 AM
talis's Avatar
talis
Hi. I'm trying to find a wiring diagram(s) for the stereo system in a 2005 Ram 3500 QC with the Infinity system with RBQ head unit. I've looked all over this forum, and others trying to find something out. Most people have said it is the same (or they think it is) as the 04, but it doesn't appear so. It has the same plug, but some of the wires are different. For example, from the head unit instead of 8 wires for all the speakers, there are only 4 (could this be the serial connection with the computer I've heard about?). Most of the other wires on the plug are the same as the 02-04 (power, ignition, dimmer), however there is no wire leading to the amp to turn it on. That is how I started to find this all out...aftermarket head unit powers up and works just fine, but no sound. I am willing to wire directly into the speakers (but I noticed that many of the lines leading out of the amp, and into the speakers themselves are the SAME color (gray with dark green or light green tracer), but I'd rather use the OE amp, since it appears to have all the crossovers and such built in, and modifying one plug behind the head unit is so much easier than anything else. So I'm also looking for a diagram describing the outputs of the amp itself. I appologize for making this so long. Any help would be greatly appreciated. Thanks
Talis
Old Aug 11, 2005 | 01:22 AM
Robert A.'s Avatar
Robert A.
I have a '05 Ram 1500, 5.7 hemi, reg. cab, short bed truck. I need a wiring diagram that will show me how to stop the seatbelt
chime from sounding when I go more than 5 mph with the belt unfastened. I don't drive without the belt on the highways, but on
my own dirt road and driveway it is a pain to listen to. Thanx.
Old Aug 11, 2005 | 02:10 AM
Natedogg625's Avatar
Natedogg625
2001 Dakota quad cab 4x4 w/ infinity system.
Old Aug 11, 2005 | 01:57 PM
Dr.Dodge's Avatar
Dr.Dodge
Alright Robert, I'll look up the accessories for you. If I recall correctly, the chime is simple to unplug....
And a Dak with infinity. NP
I'll see waht I can do when I get to work later this afternoon.
Jeff
Old Aug 12, 2005 | 08:56 PM
Dr.Dodge's Avatar
Dr.Dodge
Robert,
I posted the circuit diagram for the whole warning circuit. I also posted the connector diagram.
Nate, there is your Dak wiring for ya.
Jeff
Old Aug 13, 2005 | 12:03 AM
Robert A.'s Avatar
Robert A.
Thanx.....Igot it.
Old Aug 13, 2005 | 01:31 AM
Dr.Dodge's Avatar
Dr.Dodge
happy to help
Jeff
Old Aug 13, 2005 | 04:53 PM
daytonadriver's Avatar
daytonadriver
I have a problem with my 1992 Chrysler Daytona es. For some reason my power door locks (Lock only not unlock), my wiper delay (high/low still work), and all my dash lights stopped working. I suspect they are all on a common ground. Could you help me out with a diagram of the power lock system and any other diagrams that may help me sort out the problem.
Thanks.
Kris
