94-02 5.2L/5.9L Intake Manifold with Hughes plenum Gasket Installed
Basically Brand new intake manifold for 94-02 Dodge Ram trucks with the 5.2L or 5.9L Magnum engines, with the Hughes engines Plenum gasket fix kit already installed.
A common issue with these trucks is that the gasket on the underside of the intake manifold that separates the manifold from the valley of the engine breaks and starts allowing oil through, causing the engine to burn a lot of oil. The reason for this is, from the factory, dodge use a steel plate on the bottom of the manifold. This heats up at a different rate that the ALUMINUM intake manifold and over time causes the gasket to fail. A remedy for this is, obviously a new gasket and to prevent it from happening in the near future, I installed an aluminum plate to match the intake manifold. This kit was already installed on this manifold and is ready to drop into your truck!
I am located in Suffolk County, New York. Yes, this is Long Island.
My apologies. Does something along the lines of $200 sound good?
The Hughes kit is already installed ready to be dropped in and the intake manifold is spotless. Really could clean up an engine bay and even add a few ponies to an older engine with a dirty intake manifold.
Definitely a good price - unfortunately got laid off this week, otherwise would have taken it off your hands. If anything changes in the next couple of weeks and you still have it, I'll shoot you a PM.
