Vanix LED Off road lights
Old Oct 15, 2014 | 09:27 AM
vanix's Avatar
vanix
Former Vendor
Default Vanix LED Off road lights
Off Road LED Light Bar Pro Series – CREE Leds
Our Pro Series LED Light Bars range from 8″ to 52″ in length. Top quality item. Depending on the light bar length your vehicle requires for maximum light output, wattage can range from 36W-288W from just 12-100 High Intensity Cree LEDs. Giving off that high luminosity via Flood and Spot Combo and color temperature of 6000K, you’ll see further.
Extremely bright even in daylight.
Great for, off road vehicles, ATV’s, UTV’s, construction vehicles, farm vehicles, trucks.
Heavy duty metal housing is water and weather proof (IP67).
Mounting hardware is included.
Operating Voltage: 10-30V DC
Lens material: PMMA
FREE USA shipping.
ALL products are shipped from USA, not China!
24w - 27w LED square, circular utility pods
LED Off Road / Utility Pods are widely applied to enhance lighting e.g.
Vessels, Bus, Off-road vehicles, Trucks, Fire Engines, Forklifts, Mining, Trains, Tanks, etc.
LED Circular lights have wide operating voltage range: it can apply to different types of vehicles.
Long life: more than ordinary advanced LED light bulbs, more than 30000 hours life
Aluminum casing, shock-proof waterproof better.
Light perception: a softer light to prevent glare.
Waterproof and anti-corrosion: it can in the rain or harsh environments.
9pcs*3W high intensity LEDs
Dimensions: 128mm x 110mm x 55mm
Color Temperature: 6500K
Lumens: 1755lum
Material: Diecast aluminum housing.
Waterproof rate: IP 67
Current draw 1.7A @13V,0.9A@24V
LED Bulb SMD Maker: Epistar
PMMA lens
Opitonal Beam: Flood beam pattern(60 degree) or Spot beam(30/15 degree).
30000 hours above life time.
