AMP Research Promotion at CARiD - save up to $150!
Looking to provide your truck with the most advanced running board system available on the market? Then AMP Research PowerStep is exactly what you need! These running boards take into action with an electronic signal from your vehicle's factory door sensors and extend to a comfortable entry/exit height in under one second. When you have safely entered or exited the truck and closed the door, the PowerStep quickly retracts out of sight, hidden flush with the rocker panels to ensure a clean, original look and maintain a proper ground clearance.
Featuring a generous 6-1/4" wide step surface and a 600-lb load-bearing capacity per side, these running boards are a "step up" from traditional nerf bars and tube steps. They are controlled by vehicle's factory door sensors and powered by a weatherproof motor with anti-pinch technology for optimum safety and operation in severe weather conditions. Beside that, they have other great features, that you would definitely appreciate, when you use them.
Make stepping into your truck easier with AMP Research and use the benefit of our promotion! Purchase any AMP Research PowerStep, PowerStep XL or PowerStep XTreme and claim up to $150 Prepaid Visa Card. Don’t wait! This offer is valid from July 1 through September 30, 2017. PM me today for a quote or leave your inquiries below.
AMP Research™ | Power Side Steps, Running Boards, Bed Extenders - CARiD.com
