Make sure your Ram has optimal performance with Factory Tires on!
Old Apr 9, 2020 | 09:00 AM
carid's Avatar
carid
Former Vendor
Default Make sure your Ram has optimal performance with Factory Tires on!
Whether replacing one damaged tire or picking up a new set for the next season, you have two tires replacement options - stick with the factory size or upgrade to the bigger tires. Sticking with a factory recommended tire means that you will maintain the same gas/mileage, torque, and other driving characteristics of your truck. They play an essential role in achieving the factory-like comfort and performance.
Below you will find the list of the most popular factory tire size options available for the late model RAM 1500 trucks.
https://www.carid.com/tires/265-70-r17/
https://www.carid.com/tires/285-70-r17/
https://www.carid.com/tires/275-60-r20/
https://www.carid.com/tires/285-45-r22/
If you don't see the tire size that you run on your truck, view the full list of tires available for Ram truck here https://www.carid.com/ram-tires/
WHEEL & TIRE SIZE CALCULATOR
Using our visual wheel & tire calculator you can also check other parameters of your tires, such as the sidewall height, width, etc., or view alternative options.
https://www.carid.com/tire-size-calculator.html
So what tires will you choose for the next purchase: factory recommended size or upsize?
