Enjoy excellent ride quality with Superlift Lift Kit + Summer Offer
https://www.carid.com/superlift/
If you like taking your truck off-road, then chances are you're going to need to upgrade the factory suspension to get over all of those steep hills and rocky terrain. Be sure to pick up a lift kit from Superlift to enjoy the optimal ride and handling performance! Each kit includes everything needed for the most advanced combination of off-road performance and on-road handling. They are preset to minimize settling and guarantee to keep a consistent ride height.
This summer, enjoy a fascinating rebate on Superlift Lift Kits at CARiD! Receive a $100 Truck Hero Prepaid Card with the purchase of Superlift Lift Kit value above $499 through September 30, 2021. Please check the PDF form for a complete list of rules and instructions: https://images.carid.com/superlift/p...ebate-form.pdf
Superlift® - Master™ Lift Kit
https://www.carid.com/superlift/master-lift-kit.html
Fits:
2012-2016 Dodge Ram 1500
2WD and 4WD models
Features:
- Retains factory ride quality, steering geometry and CV axle angles
- Front track width not increased
- Front lift height range
- Full-width differential / control arm crossmembers provide lateral rigidity
- Load bearing bracketry made of .25" thick plate steel or DOM tubing
- Front differential housing does not require trimming
- Dual centerlink stabilizing links make steering more responsive and extend pitman / idler arm life
- Lifetime Warranty
