Innovative product for your car for more comfortable ride
TTC Co. introduce world's first cushion buffer made of Urethane, TTC Urethane Cushion Buffer is a innovative product that is installed in a car spring to provide comfort and safety when driving on our roads.
TTC Urethane Cushion Buffer acquired international certification KS A9001:ISO9001 in 2007 and in accordance with the national safety standards of European Union.
Explains the functions and performance of TTC urethane cushion buffer and the kinds of effect TTC urethane cushion buffer provided after installation.
Reducing a leaning phenomenon on a sharp curve
Upon entering a sharp curve, TTC urethane cushion buffer reduces a force that makes the automobile lean to a side. In detail, it reduces the horizontal force that shifts most of the automobile's center of gravity to a side when cornering; then, it improves the resilience of the automobile's body, which results in a smoother control of the automobile, reduction of the leaning phenomenon, and more stable driving.
Reducing shock upon driving on a bumpy road
It absorbs the shock from a speed bump or bumpy road and lets you enjoy smoother and more stable driving experience. An automobile with TTC urethane cushion buffer has additional shock absorbing capability and can be driven more smoothly on a bumpy road or speed bump, which has a positive effect on the life span of the automobile's suspension as well.
Vibration reduction effect upon a high speed driving
TTC urethane cushion buffer reduces vibration from the engine as well as the road, which allows much smoother and comfortable driving experience. Driving on an expressway in a high speed causes much vibration due to the road surface friction and a powerful engine output. TTC urethane cushion buffer reduces this type of vibration as well as improves the automobile's suspension functionality, which elevates the air-resistance, such as station wind and horizontal wind, and enables stable and smooth driving.
Reducing fatigue while driving on off-road
Reducing the shock and vibration on a rough off-road, which results in more comfortable ride and reduced fatigue, TTC urethane cushion buffer makes much difference in your driving experience. It also improves the impact resilience of condensed coil spring; thus, you can expect to have easier steering wheel control as well as reduced vibration and shock. Plus, it allows you to have less fatigue during driving hours and has positive effects on the physical condition of your automobile.
Information about product:
Packaging:
1 Box (2 pcs of TTC Urethane Buffer)
Material:
Made of Urethane %
Installation:
Easy of install no need to remove any part of vehicle only jack up your vehicle and install it between coil spring
Product Warranty Period
The product warranty period is 2 years from the purchased date but it can be used up to 7 years.
